You all have been hounding us for updates and rightfully-so, but please keep in mind that the window covers that you see in these pictures are going to be much tighter around the frame on the production run and were thrown on for picture purposes. The black fabric is ballistic Cordura and the vinyl window itself is fairly thick (specs updated once I get them). The windows are velcro'd around the frame so if they get damaged or need replaced you can order a replacement. The front window has a zipper so you can roll it down for ventilation. A rubber seal is also used around the door frame.
An outside FRONT door latch is provided via old-school style pull-up door lock (sorry for the low res) and this can be used even with the framed upper doors removed. The REAR doors will have a passthrough to access the stock inner door handle. As you can see, these will work with a variety of front windshields that use clamps. A front inner door pull will also be provided, which is something I wish even the stock doors had so you're not pulling on the door sill that could be covered with mud.
An inner sub frame will be provided to beef up the existing door structure as simply bolting to the stock door frame alone can pose long term durability issues. The sub frame is a one-time install and stays in place if you decide to remove the framed upper doors.
As you can see, there's plenty of visibility but the black fabric surrounding the frame may be made a little wider.
The RMAX4 rear window is 2-piece and the rear section is secured to the roll cage. UORP would like your input on what you all would prefer: no need for a REAR zippered window or if you would like a REAR zippered window and if so would you like it in the back section or in the door section? I'll probably do a formal poll after gathering some opinions.
The RMAX4 doors can be purchased as a 4-door kit, or if you're like me, and really only care about the front, you can choose to only purchase front doors. UORP will also offer a cab separator between the front/rear.
Side view mirror mounting options are being worked on as well.
Price for the RMAX4 is projected to be $1250 plus shipping.
Outer front door latch in action (once again sorry for the low res)
Pics
