161 - 180 of 222 Posts
I tried this and the rear tires ended up having a smaller diameter due to the width of the rear rims. Ended up grabbing two more fronts to complete the square set up.
....and it looked weird!
Camshaft, i followed your direction and found 2 front stock wheels to square up my rmax4. Do you think there is room for a 32x10x14 XTR370 to clear in the rear? I know your 30x10x14s look pretty tight in the above picture but not sure how each brand of tire "actually" measures in real life. I don't mind some slight rubbing at max capacity (especially if its not hurting the tire or machine) but would prefer not to have any.
Thanks
Thanks
I ended up putting more aggressive tires on a short time ago that may measure a bit taller. I'll take another measurement tonght or tomorrow am for you.
I'm gonna be due some new rubber before too long. I was leaning towards the Roxzillas but the terrain I am always in doesn't look to be the best for those tires from what I've seen. So...I'm back on the hunt. I'd like to put bead locks on there as well so I can get the pressures on down without it being a problem. I think the quest for THE tire is never-ending.
I've been looking at this setup but am lost on the offset...they say they fit the '21 RMAX2...they say..
That 6+1 offset is going to have your tires tucked in under the machine. A 5+2 would be closer to stock and a 4+3 would be wider than stock.
Anyone running the tusk terrabites in 33s?
Trying to decide between terrabites on stock wheels or going to a BFG Ko2 on 15s.
Don't care about rocks, or mud, just need a taller tire for gearing and better tread life.
TN Max,
We ride with a variety of machines and tires. I'm the only R max so I'm sorry I don't have anything to compare apples to apples to there. We do have 2 identical KRX's on 35's one with Roxzillas, one with SATV Warrior AT's. We have 2 identical RZR 1000 rock and trail editions one on 32" carnivores and one on 32" Roxzillas. And a XX on 32" terabytes (almost worn out)
The Roxzillas have out performed everything so far hands down. I read that they are poor in mud, I have found that to be not so true. They climb better than anything I have seen. The terabytes on the XX seemed to do well when they were newer but the driver was 100% wide open all the time and he was an excellent driver. Maybe that made the tire seem more capable. We are more low and slow and crawl a lot but we hit unimproved mountain trails that are soft topsoil as well.....I would assume from previous pics that your trails in the tri cities are similar. If my crew were to rate tires for the variety of riding we do it would be #1 Roxzillas, #2 Carnivores, #3 Terrabytes, and the Warrior AT's have not performed well in our terrain. They are the softer "stickies " by the way. That guy has a little over 1000 miles on them and they still have great tread but he just bought Zillas. I have 32" Zillas on my Rmax2 and I have been blown away. The side bite is unbelievable. Not trying to sway your decision these are just our observations with similar machines on the same trails on the same days. It's a $$$ decision so research it out. Looking forward to riding with ya soon
If your tires are usable.... come ride with us in a couple of weeks and you may be able to judge for yourself. Also a local ATV/SXS repair shop called Pro Service usually has really good deals on wheels and tires. May be worth a look.
I vote 4+3 with a 1"inch spacer in the rear on 4 seaters. I'm going big horn tread when I go 32s on my RMAX4.
I had to take my 1” spacers out on the back because I was throwing mud everywhere!
Lol, it was like driving a trike with no fenders. 😂
I'm currently running 32" 370's on 4+3 beadlocks which work really well for the terrain I ride. I think they grip better than the stock Carnivores but that might be wishful thinking. I was waffling between the 'Zilla's and 370's but the Roxxzilla's were only available in stickies at the time of purchase. There's a lot of hardtop riding in West Virginia and stickies didn't seem to be a good fit. When the System 3's are worn out I'm going to try the 'Zilla's.
I read good reviews about the system 3's👍👍👍
