RMAX INNER FENDER GUARDS
Link: Home Page - SuperATV
Keep the Trail Out
When you ride on rough terrain, your front tires kick up all sorts of debris that beats the hell out of your fender wells. Without protection, rocks and sticks can damage your machine or injure your passengers. Get protected with SuperATV’s Inner Fender Guards for the Yamaha Wolverine RMAX. They keep debris out and keep you safe.
Lightweight Aluminum Strength
You need RMAX fender well protectors that can stand up to everything your Wolverine was built for. That’s why we make them with 1/8” aluminum plating that’s protected by a UV-resistant powder coating. They’re strong but lightweight and bolt directly to your frame—nothing’s gonna knock them loose. They’ll make sure your UTV stays in one piece.
Doesn’t Limit Your Max Tire Size
Most inner fender guards limit your max tire size, but ours are carefully designed to stay out of the way. Your tires will rub on your stock components before they touch our guards. They’re a no-compromise upgrade. So what are you waiting for?
- Made of heavy-duty 1/8” aluminum plating
- Over 5 times stronger than your factory firewall
- Bolts directly to your frame
- Compatible with all A-arms
- Does not affect tire size
- UV-resistant powder coating for long-lasting durability
- Yamaha Wolverine RMAX 2 : 2021+
- Yamaha Wolverine RMAX 4 : 2021+
Keep the Trail Out
