Learning a few things today so I wanted to share. So this post is the learning curve.
This will all be cleaned up and redone.
First is the Cling wrap. Here is a pic of first attempt. Looks good, but I don't like it. I used 2 long pieces of wrap, cut X in center and X wrapped.
This stuff is cheap so don't be stingy with it. I plan to wrap the piss out of the sheave halves and use scissors to trim just inside the rivet heads. I'll get new pics later.
Yamaha calls for 5g (1.2 teaspoons) on the inside of the sheave shafts. I used measuring spoons to get a feel for amounts. I applied the 5g to the insides.
It was pretty close, probably a lot less than I actually removed during cleaning. The sheave shaft doesn't contact the driven shaft in this area, so I can only conclude it's to weep out if needed with centrifugal forces.
There's no way that old grease could be a benefit in this way as it just plugged up the holes and filled voids inside.
Pic of Driven Shaft. The inner fixed sheave area that calls for grease is between the drive splines and outer journal area. It's lower than the journal which lead me to the centrifugal force idea.
I pretty much followed Massive's video and didn't measure quantities. I am using the old seals (back order), so tolerances are not as tight.
Once I got the sheaves greased and cup installed, I worked the sheaves back & forth and kept getting a line of Tinkseal between the sheaves.
The more I worked the sheave while cleaning between them, the line of Tinkseal was getting smaller each time. Again, new seals would've probably eliminated a lot if not most of this.
I did install the new O-rings.
I finally decided to take everything apart to see & learn what the lube pattern is looking like.
Here are the pics.
Grease line is smaller and I could've probably continued working and cleaning until it was eliminated, but like I said, I wanted to learn the lube pattern.
I will completely clean everything up and just for curiosity, measure/apply the grease focusing on the areas that show up in the lube pattern.
Notice the lube pattern in pic below. That bottom clean area measures 3/8" and the top area is 3/4" while the grease is collected between them.
Time for a beer and back to cleaning....lol
Edit: added pic
