WHEELS FOR MY RMAX
Tags
wheels
9.3K views 13 replies 8 participants last post by  kdt1970
#1 ·
Hello, I know I'm not the first to ask this question, but I would like to buy some wheels for my RMAX2SE so that I can fit my winter tires. My tire size is 30 x 14 x 10. I know the bolt pattern is 4/156 and the original wheel is 6.5¨ wide. On the other hand, I do not know what the numbers which follow the bolt pattern mean, for example 5 + 2, 3 + 4, etc. Can you explain to me what it is and what is the correct one? Could you also suggest some wheels, make and model with the original sizes that work well on the RMAX?
Thank you very much!
Discussion starter · #4 ·
You want 5+2. See this thread:
Thanks for the information. So to be sure I found the System 3 brand, model ST-3. Here are the specs:
14 X 7
4/156
5 + 2
So can I order this wheel even though the original wheel is 14 X 6.5?
Thank you
Discussion starter · #7 ·
Thank you
They will fit, however your overall width will increase.
Besides being a 1/2" wider, they are 30mm offset compared to 34mm for stock.
Hello, will the total width of the vehicle increase? Because the tire is still wider than the wheel? 10 inches vs 7 inches? I'm asking you the question, because in Quebec, in federated trails, the maximum accepted width is 66.1 inches.
