We bought our Wolverine last October. Here it is July and we STILL have never had the darn thing out!! Crazy we know. Over the past few weekends I've built a rack for the back of my Dodge so we can load the Yamaha and still pull our camp trailer (we have a 2006 Ram 2500 Cummins). So the rack is pretty much done, and the plan all along has been to simply winch it up using the Warn 3000 we had installed at the dealership when we bought the machine. But then I got to thinking about the winch and the small, non-deep-cycle battery on the Wolverine. I know the winch has plenty of grunt to pull the Wolverine up onto the rack....... but does the stock battery? I'm concerned the battery will not survive a winch up and then a winch back down, and still have power enough to start and operate the UTV. Admittedly I'm new to this UTV thing, I don't know what to expect. But from my experience with winches (minimal) and from my research, winches require ALOT of battery power. The entire winch pull will be about 18' from the start of the ramps to its final spot on the rack. The rated line pull speed for the Warn 3000 is about 9' per minute at 1200-1300 lbs, the weight of the Yamaha. The amperage draw at this weight should be somewhere around 70 to 80 amps, and maybe as much as 100. At this rate of pull, it will take about 2 minutes of actual winching time to pull the Wolverine onto the rack, not accounting for a cool-off break after a minute or so. Then of course once we reach our destination, we'll have to winch it back down again. I considered using a winch mounted onto the rack instead of using the winch on the Wolverine, and using the dual deep-cycle batteries on the ol' Dodge to power it, but this seems like a waste of the perfectly good and already perfectly mounted winch on the front of the Yamaha. Also, the winch on the rack idea would require some interesting pulley and cable routing engineering that I simply want to avoid if possible.
So, what can I expect? Is the stock battery enough to do this several times a season? Am I worried about nothing? Should I replace the stock Wolverine starting battery with a deep-cycle unit? Should I start the Wolverine and let it run while winching up, or will this even matter? Does the Yamaha stator provide enough juice to make a difference? Can I supplement the stock battery with a secondary power source, such as a bigger battery in the bed of the truck and some sort of quick-disconnect harness for the winch power? Please advise!!
I apologize if this is in the wrong section, and if so, mods please relocate. Thanks everyone for any help!
