RMAX4 - will 33" XT370s fit?
112 views 5 replies 3 participants last post by  10ft7wt
#1 ·
What do you think, will the 33" System3 XT370's fit on a 24' RMAX4? I've got Bandit tender springs and my rear ground clearance is 16" right now. I want to go with the 33" tires because they have the taller lugs (1" tall vs 3/4" tall on the 32s). Anybody out there have this setup?
#2 ·
I think you'll need our forward A-arms to prevent any rubbing with those 33"s.
These arms will allow you to run 34"s easily.
#3 ·
They will rub hard and customize your plastic on the back end under compression as well.
#4 ·
Gotcha, so 32s are the way to go unless I get into new A-arm or portals.
I read that true 32s rub slightly on full compression on the compacts, I'm ok with a little "custom plastics" as you say @Budro2!
Reactions: Budro2
#5 ·
Honestly, when ORTraveling Rmax put 32s on that we’re larger than 32, it slowly carved it out so pretty that it wasn’t an eye sore and no one would notice if it wasn’t pointed out.
I will say though, if you don’t do serious CVT changes for a improved ratio, you will 100% glaze your wet clutch over time and while it will still work, it will slip at slower speeds a lot creating high RPMs at slow speeds.
Reactions: OR Traveling Rmax
#6 ·
@Budro2 , 10-4. I was expecting to do a 1mm shim in the CVT. Is there anything else I should be looking at? Possibly different clutch weights? I applicate the help.
