Industry’s Most Versatile and Reliable Inverters, Generators, Pressure Washers and Pumps
CYPRESS, Calif. – June 11, 2015 – Yamaha Motor Corp., USA, is producing an expanding line of the most durable, versatile and reliable power products including a variety of inverters, generators, pressure washers and pumps for 2015.
Two of the newest models in Yamaha’s Power Products line are the PW3028 and PW4040 pressure washers. These pressure washers offer pro-sumer and industrial grade pressure combined with unique features designed to handle any environment. With useful and versatile attachments along with a powerful OHV engine and a reliable brass Triplex CAT Pump®, the PW3028 and PW4040 pressure washers are unmatched by competitors.
Yamaha’s line of clean and efficient inverters and generators ranges from the lightweight EF2000iS to the safe and powerful EF12000DE.
Every inverter, generator, pressure washer and pump in the line is powered by a Yamaha Overhead Valve (OHV) air-cooled, single cylinder, four-stroke engine resulting in noise-reducing operation, improved efficiency, increased reliability, and low oil consumption. All Yamaha power products also meet emissions durability ratings issued by the Environmental Protection Agency (EPA) and California Air Resources Board (CARB), passing emissions
regulations in all 50 states.
The EF1000iS is the smallest in Yamaha’s inverter series weighing less than 30 pounds. Capable of producing 1,000 watts for up to 11 hours, the EF1000iS is perfect for tackling the small jobs.
Next in Yamaha’s inverter series are the EF2000iS and EF2000iSH (wrapped in Realtree AP® camo pattern). At just 44 pounds, their compact, lightweight size fits in at off-road staging areas, hunting and camping trips and as a back-up or emergency power around the house. If just one isn’t enough, the EF2000iS and EF2000iSH are equipped with a parallel function that lets you connect two generators and deliver up to 30 maximum amps.
Other lightweight options in the Yamaha line include the EF2400iSHC, EF2600, and EF2800i. These inverters offer even more power and longer run times while still weighing less than 100 pounds.
The EF3000iS and EF3000iSEB can produce up to 3000 watts, and can run continuously for up to18 hours at a quarter of the rated load. They are powerful and portable enough to run a full campsite overnight. The EF3000iSEB also features Yamaha Boost Technology making it ideal for the RV enthusiast that needs power for either a fifth wheel or travel trailer.
Continuing up the Yamaha line, the EF4500iSE and EF6300iSDE provide additional fuel-efficient power options, and can run almost any type of equipment from high-demand RV air conditioners to sensitive electronics like smart TVs or computers.
Yamaha’s industrial series of generators are made for bigger jobs and commercial operations. They include the EF2600, EF5500D/DE, EF7200D/DE and EF12000DE. Both the EF5500D/DE and EF7200D/DE models are powered by Yamaha’s MZ360 engine.
.jpg)
Yamaha also makes moving water easier with two clear water centrifugal pumps: the YP20G and YP30G. For tougher jobs, the YP20T, YP30T, and YP40T can handle solids up to 1-1/16 inches and make clearing water on the jobsite a snap.
All power products are offered with a standard three-year warranty, though customers can also purchase a Yamaha Extended Service plan for an additional one, two or three years of coverage. For more information on the full line of power products, or to find the closest dealer visit Yamaha Power Products, Generators, Pressure Washers, Pumps or call 1-800-88-YAMAHA.
