so its been a while, work is getting in the way of rmax build.
I was in the middle of starting the front bar build when i realized as i didnt have the front screen fitted i could not finish the main bar hoop that will meet the a pillar.
so i jumped from the bar to the screen fitting.
long story short, i pre ordered my screen months (years) before my machine showed up, in that time satv had changed there mind on the correct part number my rmax 4 should have.
so i was sent the wrong one, its a long way to send it back so i decided to bit the bullet and make it fit. photos attached , seems to fit up ok, the lower is the same, it was just the upper that was a pita. I had to cut a lot out especially in the corners. but its on and working ok so far.
so the kit i fitted was FWS-Y-RMAX-70. and i fitted it to a 2022 rmax-4.
