1 - 20 of 95 Posts
Is Superatv working on offset a arms for the wolverine X4? If so, any kind of ETA? Thanks
Sent from my SM-G892A using Tapatalk
I suppose they won't be making any for the 2018 and below R-spec will they?
Hey! I definitely put it on my request list a few months ago. Its on our engineering wish list, but we haven't drawn up a prototype yet. I went back and rattled the cage a bit after reading this to try to jump start the project.
Any progress?
Reactions: wolvymanx4
Vendor
Yep! I'm pretty sure...as long as they check out ok. We were going to try some proto forward arms on soon. Not sure if its done yet or if its passed the test, but I'll check on Monday.
Thanks!
Just spoke with my PM over these arms, and they passed the test. We're going to kick off production in a few weeks, and we should have the first batch ready around the middle of November.
Thank you. I'll be ordering a set as soon as they are available. What about axles? Nobody makes an aftermarket axle for the X2/X4 that I'm aware of. There is a need for tougher axles besides OEM.
Awesome! Just in time for xmas. Are these front and back or just front? I rub on full lock if I articulate too much. The rear is close and not sure if it runs. Either way I'm glad yall are working on this!
Vendor
Good question. I asked a few months ago, but they weren't in the plans at the time. I haven't heard about many stock axle issues, so they went to the bottom of the priority list. Are you breaking a lot of axles? Same ones?
The X4 (2018/19) needs rear off-set arms to space the wheels from the frame... I am pretty sure that I am not alone in asking for a little more room between the tire and frame.
2021 RMAX4 1000
Agreed. Surprised to hear it's just fronts. I would have thought the rears would have been the priority for the X4. With 28's I've never rubbed in the front. I do have an aggressive offset wheel but most running the same size wheel all the way around get wider in the front. Nevertheless the front is dandy. The rear is the fire that needs to be put out.
Subscribing to this thread. Hopefully we can have some info soon on either the new a-arms on the 2020’s or an aftermarket solution. I’d happily open my wallet to any solution that would give more clearance without the potential issues that the current lift kits seem to have.
Reactions: SuperATV
Vendor
Question...
How big are you wanting to go? Not sure if we're doing rears yet, but there are some builders in your area that can fab up some pretty sweet arms and lifts. I doubt it'll be a bounty hole competitor, :bandit: but I can connect you to a few custom shops if you're trying to make a monster...
Question...
I was going to probably stick with 33s if I could. Not sure but thinking that's it with some front and rear offset arms. 35s would be cool. I was talking to someone a while back about some and was a little too expensive for me.
I'm wanting to check out the 2020 x4 changes. From what I can tell the rear arms are offset 1 extra inch from mine. Shock also has a different part number so not sure if the arms are a direct swap or not.
1 - 20 of 95 Posts
