In my experience, OHC motors with shim/bucket type valves hold their adjustment longer and generally tighten as the wear. That means hearing a difference is less likely. OTOH, an overhead valve motor with adjustable rockers seem to need more frequent adjustment, but you can hear them as the loosen and they are easier to adjust. With that in mind, I am surprised at how often Yamaha recommends a valve adjustment. The first one at first oil change and then every 1500 miles. My FJR required a valve adj every 25,000 miles and I didn't have to make any changes in the 30,000 miles I put on it. I realize the vast differences in use and execution, it just seems over done every 1500 miles.
I did my first oil and filter at 100 miles. Now I am around 300 miles and am curious what you all have experienced? My dealer says about $350 if they have to adjust, less if they check out ok.
What has been the real first hand experience?
