And maybe a little metal massage! But that's some long legs and would be great in the rocks for clearance!Might have to do some down and dirty Plastic Chopping![]()
a Pioneer 500 with 30's, that would be interesting to see....After break in I will install 27 inch Big Horns. Later I will install my 30 inch Mongrels. I expect the 30's will not clear but I use them on my Pioneer 700 and Pioneer 500. The little 500 pulls them OK going uphill in 5th gear.
Hondabob, it looks like you have 30's on the front and 27's on the back! Smooths out the ride on the front end and still allows the engine to work easier with the 27's.After break in I will install 27 inch Big Horns. Later I will install my 30 inch Mongrels. I expect the 30's will not clear but I use them on my Pioneer 700 and Pioneer 500. The little 500 pulls them OK going uphill in 5th gear.
The pioneer 500 has 30's front and back and it has a 5 speed trans so no problem with the super large tires. Stock is 24's. I use it to ride the 50 inch quad trails and use 27 inch Big Horns for trail riding. I will install the 30's on my Wolverine but just for pictures and to see if they clear. I will only go up one size to 27's for better belt life and to be easier on the wet clutch on take off. The Wolverine may have better take off after break in. If I need lower gearing I will go with a JBS modified sheave so the belt will go lower up front and higher in the back thus providing a lower take off gear. Their roller replacements will gear it up more for a higher top speed of 59 mph. That will let you cruise at 50 with out buzzing the engine. I think at 59 mph its at red line. I will check it out after breakin with a gps and my tach.
Thanks For trying the 30's on the Wolverine, can't wait to see the pics!The pioneer 500 has 30's front and back and it has a 5 speed trans so no problem with the super large tires. Stock is 24's. I use it to ride the 50 inch quad trails and use 27 inch Big Horns for trail riding. I will install the 30's on my Wolverine but just for pictures and to see if they clear. I will only go up one size to 27's for better belt life and to be easier on the wet clutch on take off. The Wolverine may have better take off after break in. If I need lower gearing I will go with a JBS modified sheave so the belt will go lower up front and higher in the back thus providing a lower take off gear. Their roller replacements will gear it up more for a higher top speed of 59 mph. That will let you cruise at 50 with out buzzing the engine. I think at 59 mph its at red line. I will check it out after breakin with a gps and my tach.
