It seems to me that the wolverine is more comparable to the wildcat sport and not the trail since the trail is a 50" machine and both the sport and wolverine are 60" machines but none the less it has basically the same suspension travel with higher CG then the trail but the width of the sport so just in that aspect it comes in behind the trail for me just my $0.02
The trail cat should be superior in acceleration and torque due to its engine being a twin. The cat should also handle better at high speeds due to its engines placement and lower center of gravity. Can't wait for real world comparisons.
Yes it will, I have a feeling this machine is pretty peppy.that didn't work with the 800 vs 570 rzr. this machine is gonna fool some people on power and handling
Well it might be peppy but it still has no suspension travel compared to other 60" machines really makes me wonder if the spec isn't correct and it's actually 50.6" that would make more sense
they dropped the ball based on the spec sheet and let's be honest that's all we really have to go on so far
After putting thousands of miles on my RZR570 and 05 and 08 Rhino I can tell you guys this Wolverine will perform well. The Trail Cat will need the high end elka shock model to better the Yamaha and it costs a few thousand more plus its a 100% sport model. Check out the video where Yamaha shows the Teryx shock beside the KYB Yamaha shock. I put over 21,000 miles on my 08 Teryx and 2012 Teryx 4 and the travel and shock quality makes it in the utility family. The Wolverine is more sport then utility mostly due to the suspension. It is faster then the Teryx and has more HP and that's more then 57. The Rhino's had 40, the Viking has 47.
There is no doubt the base model trail leaves you wanting more in the shock department but I have a base model trail with 29.5 OL 2's with the shocks cranked up for GC and it rides pretty smooth for the riding I typically do very rarely does my speedo see more than 25 mph so the shocks aren't that big of a factor and I would guess that most ppl looking to buy the wolverine will very rarlely be hitting trails at huge high rates of speed where the shocks will really show up I'm not knocking the wolverine at all but if I was in the market for a SxS there really isn't much to push someone towards the wolverine other then the reliable history of yamaha and it may make 60 hp but so does all it's competitionAfter putting thousands of miles on my RZR570 and 05 and 08 Rhino I can tell you guys this Wolverine will perform well. The Trail Cat will need the high end elka shock model to better the Yamaha and it costs a few thousand more plus its a 100% sport model. Check out the video where Yamaha shows the Teryx shock beside the KYB Yamaha shock. I put over 21,000 miles on my 08 Teryx and 2012 Teryx 4 and the travel and shock quality makes it in the utility family. The Wolverine is more sport then utility mostly due to the suspension. It is faster then the Teryx and has more HP and that's more then 57. The Rhino's had 40, the Viking has 47.
