1 - 20 of 24 Posts
Vendor
We just got some billet aluminum exhaust tips in stock in a matte black finish
Lowers exhaust temps
sounds throaty
slight performance gain
Spark arrestor spring, wrench and mounting screws included with the tip plus shipping to any lower 48 state
click link below to go right to it on our site
Link to the tip on our website
You may find it necessary to add the power commander in some cases if it stalls. The factory fuel map is lean during cruising and in some cases with the tip it might stall. Did not occur here but others have seen this observation
It appears more people need the power commander anyway to get rid of the factory lean condition causing other issues mostly engine and exhaust heat.
Todd
It's a useless piece of crap to appease the EPA. It injects air into the exhaust port to burn off excess hydrocarbons. The YXZ has it too and Graves motorsports came out with blockoff plates for it.
Look at the Head's part diagram. The solenoid is Part#24 Here are the rest of the peices.
19 2MB-E482K-00-00 PLATE $29.20 $26.86
20 2MB-E4890-00-00 REED VALVE ASSY $24.36 $22.41
21 2MB-E4889-00-00 CAP, CASE $30.52 $28.08
22 2MB-E6777-10-00 BOLT $2.80 $2.66 2
23 1XD-E4881-00-00 HOSE, BEND 1 $6.28 $5.97
24 2MB-14840-00-00 AIR CUT VALVE ASSY $64.00 $56.32
Engineer
It's an Air Induction System mixes air into exhaust gas; the Yamaha AIS is directing air into the engine for exhaust cooling. This also aids the catalytic converter & meeting emissions. It's supposed to aid proper combustion in a stock system. Once you change anything, get rid of cats, etc. it's pretty much useless, & will cause popping of the exhaust during decel. Something that needs to be blocked off and re-tuned.
Fuel map will be off from actual AFR. Probably not enough to matter. Disconnecting will not throw any codes but not sure if it leaves in open or closed state. On the R1, YZF and so forth there are machined block off plates. I think there is a AIS delete kit for the raptor too.
The extra air will make the popping on decel worst just like an exhaust leak will.
Engineer
Thanks for the information Deeyoh. I didn't know there was an ais valve on the engine. Machined block off plates are the way to go. It will change the maps a little for sure and something I will address. I have a couple of work arounds I can do with mapping which I will try later today on Boss's Wolverine.
Engineer
I was able to finally get Boss's Wolverine tuned without modifying the ais valve. He has reported no deceleration popping, better starting and better power through the powerband. I will tune with the ais blocked off as time permits.
1 - 20 of 24 Posts
