1 - 3 of 3 Posts
I would like to see a list of the items that others recommend to inspect when buying a new Wolverine, before leaving the Dealership with it. Some I can think of just from past posts and experiences are:
1. Inspect Rear Differential Vent Hose for adequate attachment.
2. Inspect all six (6) grease zerks to see if greased.
3. Toe-in within Yamaha specs.
4. Any strange or unusual sounds from CVT
5. Coolant at proper level
6. VIN on machine matches Bill of Sale and Certificate of Origin/Title
Check for fluids. Walk around and look for black lines on all important bolts .. most mechanics will make some mark in assembly to note they have done things ... check tie rods for tight lock nut diff drain plug and fill. Most importantly check for a full tank of fuel them cheap pricks try to avoid it in your excitment
1 - 3 of 3 Posts
