Rock sliders ordered.Have before machine. The wait is killing me !
Did yours come with hardware? Mine didnt and I can’t figure out where it bolts to. Am i right in thinking the larger hole on the bottom so you can get a socket through but what does it bolt toI got the rear bush guard installed today. Had to get my wife to hold up one side while I got a bolt started, these things are a trick to get the guard, spacer, and weld nut all lined up at the same time...everything moves!
It's not too difficult on a 12v DC system. You have a positve and a ground. Most problems occur because of a bad ground. Ask a question on this forum and you sure to get some help.Very cool and nicely done! Wish I had the skill/knowledge to start wiring stuff...I am afraid I would burn something up
Did ya get the rear one as well my rear kne came in no instructions no hardware looking for help
Awesome thanks! i did find the hardware wrapped in enough bubble wrap to ship the mona lisaYes, mine came with the hardware.
If you look just outside where the pivot pins are on your bed you'll see angled frame brackets with two holes in them. There is an aluminum spacer that goes inside of those brackets and bolts go through that and there is a weld nut (two tapped holes on one plate) that goes on top.
I'll see if I can get a picture when I get home tonight.
When you bolt up the rear brush guard make sure you reverse your hinge pins for your dump bed. I failed to notice that part of the instructions and had to unbolt the brush guard and reverse my hinge pins.Awesome thanks! i did find the hardware wrapped in enough bubble wrap to ship the mona lisa
put in some heated seat
What brand of heated seats did you buy? I like the switches also. Picking your brain!!
How was the i stall? They threw in a poly windshield when i bought mine but will get a glass one next
I woke up to a crap ton of snow today and my cover was pretty frozen. I probably wont be able to play with it until my next days off. By then things are hopefully defrosted a bit.How was the i stall? They threw in a poly windshield when i bought mine but will get a glass one next
Ordered the turnpro universal signal kit, with the horn, smoked amber lights, green rocker indicator switch and rocker hazard switch. Looked like a quality plug and play kit. They have other stuff too.
Yep, but for a plug and play harness and matching parts, my time and convenience is worth more than the cost of the kit vs building my own.Let us know where you mount the lights.
Convenient to get as a package, but one could probably get all that for 25-30 bucks.
BummerI woke up to a crap ton of snow today and my cover was pretty frozen. I probably wont be able to play with it until my next days off. By then things are hopefully defrosted a bit.
Jimbo: please post pics when installed. ThxOrdered the turnpro universal signal kit, with the horn, smoked amber lights, green rocker indicator switch and rocker hazard switch. Looked like a quality plug and play kit. They have other stuff too.
