1 - 5 of 5 Posts
2021 X4 xtr
Can you use a set of X2/X4 front piggyback shocks on the rear of an X4 as a replacement for the self leveling shocks? If so, any disadvantages to this setup? I just don't like the idea of not having any adjustability out back. And, with everyone upgrading their shocks all the way around, I was hoping I might be able to find a used front set for cheaper than a new set of aftermarket.
Thanks
Jeff
2021 X4 xtr
Discussion Starter · #2 ·
No one has any thoughts on this? I would have thought this would be a good low budget upgrade for the X4. If not the X2 shocks, what would you use if you were only going to change out the rears on the X4, for now?
Thanks
Jeff
Many Many threads on this.
Shock Length is a issue if I recall.
Most just upgrade to Walker Evans, best bang for your buck for ride quality and durability.
Several threads on it also.
Good Luck.
1 - 5 of 5 Posts
