I would like to see someone like SuperATV develop tubular uppers with some sort of door jammed attached to ROPS kits. Let’s get it SuperATV hate the fact you gotta remove these awesome doors for a hard cab kit.
I brought up something like this recently. Not sure if we're on the same page, but I was thinking some easily installed and removed upper door sections made out of the same material as the windshields. Not really a full cab, but more just an upper door enclosure. Same concept? We're awesome at the full cab enclosures, but that would be a complete system with full doors.I would like to see someone like SuperATV develop tubular uppers with some sort of door jammed attached to ROPS kits. Let’s get it SuperATV hate the fact you gotta remove these awesome doors for a hard cab kit.
That would probably work, with a slider section to open the door and ventilate! A little 90 degree bulb seal around where it meets the cage, and an easy on / off hand screw mount would be awesome. Simple and effective, very few moving parts..I brought up something like this recently. Not sure if we're on the same page, but I was thinking some easily installed and removed upper door sections made out of the same material as the windshields. Not really a full cab, but more just an upper door enclosure. Same concept? We're awesome at the full cab enclosures, but that would be a complete system with full doors.
Don't forget the X2/X4 owners. If someone builds those for our machines we would buy too.At this point, easily-removable upper doors with solid hard-coated poly windows is fine, but frames that had zippered vinyl inserts would be great as well to run year round. Whatever can be brought to market quicker I'm all for.
2021 X2/X4 owners could use them (well the fronts), but pre 2020 X2/X4 owners couldn't. The new 3 piece doors make it much easier to implement an upper window vs the molded doors of previous years.Don't forget the X2/X4 owners. If someone builds those for our machines we would buy too.
I've been pumping this to the boys in engineering since you brought it up when the RMAX was first dropped. Fingers crossed...I hope they add it to their list.At this point, easily-removable upper doors with solid hard-coated poly windows is fine, but frames that had zippered vinyl inserts would be great as well to run year round. Whatever can be brought to market quicker I'm all for.
