Hey guys, I'm a new member, been lurking on this forum for awhile, looking at pulling the trigger on a Wolverine. I have a question about tires and was hoping to get some feedback. I see quite a few of you are running set ups that include one size wheel on all four corners and different width tires on the front and back (i.e. 12x7 wheels with 27x9 front tires and 27x11 rear tires). Does this cause any problems for you? As I see it you would have a taller tire in the rear with this set up, as the 7 inch rims would squeeze the 11" wide rear tires making them taller. Just curious as my plan is to keep the stock wheels, and possibly put 28x10 tires on all four corners achieving essentially the same result of having taller front tires compared to the rear. Any advice on this would be appreciated. Thanks.
