1 - 20 of 71 Posts
I have an open trailer and when bringing my Wolverine home, I had difficulty deciding where to place my straps to tie it down to the trailer. I have custom made ratchet straps with D rings so I can go around round tubes and back to itself. On the rear I went to the safety chain connection holes on either side of the 2" receiver hitch, but on the front I wasn't so sure. I used the a-arms, but the straps slide over to the plastic CV joint guard which will eventually ruin a strap. Where are you guys attaching your straps? Pictures are appreciated.
I incorporated this mounting point into my home made winch mount.
I utilize my RZR extractor in the rear for tie downs.
Reactions: Abell34 and MORSNO
I use wheel straps on the front wheels. Its never moved on me going out some pretty questionable roads at good speed.
Reactions: TC618 and MORSNO
Its hard to see in the pic but I strap mine down front to back and back to front. In the rear I hook onto the 2" receiver and in the front I hook onto the triangle shaped gussets (Might not be the strongest point but its better than hooking onto a A-arm, etc and it works for me) on the frame behind the front tires. The road into our regular park has nasty hills and rocky as hell so it get tossed around pretty good and I have yet to have it move an inch using this method.
Reactions: MORSNO and TC618
I have a car hauler that has a bump stop at the front. I pull all the way up to the bump stop. I run a strap around the center of the front bumper and secure it to the front of the trailer by the hitch. Then I simply run 2 on the back. One through each eyelet on either side of the Wolverines hitch going to deck hoops that I installed. Never had an issue. Even with the trailer going airborne last fall after hitting a huge hole in the road.
There is no good or bad way really. Just put a strap at each corner and ratchet them tight. Check at each stop.
I use the retractable ratchet straps available from etrailer.com. They bolt directly to your trailer so they are always there and the straps are made from seat belt material so they just don't stretch much at all. When you un-hook from your Wolvie they automatically retract back into their housing. I use them in conjunction with motorcycle straps and my Wolvie doesn't move during transport. Easy peasy. https://www.etrailer.com/Cargo-Tie-Downs/CargoBuckle/IMF18800.html
Discussion Starter · #11 ·
Just a quick update on my tie downs. This weekend at our annual Great Alaska Sportsman's show I saw a trailer vendor that had a SxS tied down with a set of tie bonnets. They didn't have any at the show, but at their shop they had a new variety of Mac's tie downs in stock. I picked up a set of 4 wheel nets/bonnets and a few more tie down anchors for my trailer at a pretty good show discount. I'll post up pics next time I load my Wolvy up. Mac's wheel nets, wheel bonnets, tie-downs, and spreader bars
This is how I have been doing it.
In all seriousness. 2 in the back on the trailer chain loops. I do one in the front around the push bar since I have a metal bump stop on my car hauler. People seem to over think this. Just stick one in each corner and ratchet it down nice and tight and check at each stop.
November WOTM Winner!
I know. I usually tie mine down on the 4 corners pulling out, then it can't really go anywhere. Seen too many people pull straight down then hit a bump going down the road and it shifts because of the suspension
Discussion Starter · #14 ·
I've always dome the four corners also, I just didn't like the front ones rubbing on sharp objects, the rear was easy. These wheel nets make it super easy and lock it down good.
Those are cool, a bit pricey.. I wonder how they hold up after being in the elements. I always have to replace my ratchets due to mud, dirt, weather, etc.
Discussion Starter · #16 ·
man I'm gonna get ragged on this one, see it comming:)
How far did you go like this? A quick braking action and a jack knifed trailer would not be pretty! I also wouldn't trust the winch holding with the jerking on the gears, they can strip with the jarring as the suspension bounces. You do have side rails and a rear ramp, but dang dude! Any load over 10' is supposed to be strapped down front and rear also....but you southern boys live differently :D
Reactions: LeadSled01
Walters, Walters, Walters.............SMH..........
Yea I wouldn't trust the winch either. I go to all 4 corners, perhaps it's overkill. I figure better safe than sorry. I think at a minimum you should have it tied down front & rear. With it only tied down in the front a sudden maneuver could cause the rear of the buggy to shift sideways or worse. I'm sure you are a very good driver........it's always the other F$%^ head I worry about.
Reactions: Kirk57 and MORSNO
1 - 20 of 71 Posts
