1 - 5 of 5 Posts
The Tusk ball joint tool is to small in diameter and the screw is a tad too long to do the hub side ball joint. I was able to modify it to get it to work just fine.
-ground out the inner surface to clear the ball joint lip
-cut .5" off the top of the nut to get it so it fits on the hub ball joint.
96540
96541
96542
Much better results than pissing and moaning that something doesn't work. Kudo's on your ingenuity. (y)
Yes Sir, good work indeed!
1 - 5 of 5 Posts
