When my wolverine is facing uphill after coming out of park or reverse when i put it in low you can hear the trans almost engaging but it will pop pop pop then BANG when it finally does. Never does it going into high or back to reverse. I think the connecting rod from the shifter handle to the trans could be lengthened or shortened to solve it. I looked at the rod and it does have nuts on each end so it should be simple. Just wondering if anybody had seen this or had ideas. Thanks
