Thank you! I have a 2006 rhino that "might" need an overhaul. I can only do about 50 in it. It has 3500 miles which I'm kinda bummed about. I have been very religious about oil and filter..... I'm debating on buying new or rebuilding the rhino. Is it that much better? There is one at local dealer 60 miles away.
Timmi, what is a "slugged clutch"?. I know it is a kit but please define.Bone stock other than the Hunterworks sheave, slugged clutch, and a drop in o.d. weights, we ran 59 mph on level ground with two 240 lb. men aboard.
As Test Master said, 52 mph stock.
sounds like a good benefit. any detriments?"slugging" is adding additional weight to the ends of the shoes in the centrifugal clutch. That makes them move outward out more which makes the clutch engage earlier and harder as the engine revs up.
None. Belt stays engaged so it lasts longer, better acceleration and engine braking.sounds like a good benefit. any detriments?
