The power was great, being the modder that I am I'll probably add exhaust and sheave etc. But I really don't think I need it. I'm at sea level so I get full power from the engine.Did it have plenty of power when you were in deep mud and water and all that? Did it ever lack power? I've got one but haven't had a chance to ride it much due to work and never ending rain.
Thanks the wheels are 14in MSA Kore. I had them custom powder coated. They strip the flat black color, then powder coated them chrome, second coat is candy translucent lime green, 3rd coat is a clear coat with uv protection.I like the wheel and tire combo you got there looks niicee. What kinda wheels are those?
No they don't rub, they aren't even close to rubbing, you can fit 29in, maybe even 29.5in tires without rubbing. Spring preload is factory, I haven't adjusted anything. I want to get the tool to add preload, only because it drops a bit when loaded with passengers and coolers.. But that's to be expected.Tires ever rub when loaded down? Also did you Crack down the preload on the shocks any?
Mud lite, sti outback.. Both good tires, not super expensive, and work well on hard pack and slop. Both can also be bought in versions for 12in wheelsI'll probably hold onto them for a good while as I just mostly ride on the deer lease and hunt out of it. But I've been reading where some have said that they are pretty light weight, 2 ply I think.. if they go to giving me problems I will change them quick. I'm thinking they should hold up okay for what I'm gonna do with it, but we will see. What are some good tires that I can put on it and keep the stock wheels?? If I get new tires I probably wont get really tall tires... maybe 28".
I know the mud lite work, the sti outback also come in 27in also.. Both will give you a smooth ride and traction in mud or on hard pack.Any suggestions on a good 27" BA lookin tire to run? I've had mud lite xls but I've been looking at mud trax and mega mayhems. Any thoughts?
Tires - Mud Lite XLWhat is the weight of the Mud Lite tire?
