Last year I installed the thermo-bypass valve in conjunction with an inferno heater in my rmax and I was informed that i did it wrong (story of my entire life). Today is the day I fix it and I still don't know the right way to install it, even after a search. Its currently installed in the lower passenger wheel well in replacement of the Y-connector. It should be connected to the coolant line on the driver side of the tunnel. So my question is: What direction does the Y-connector go in the lower wheel well. And: What direction or orientation does the bypass valve go once I get it located under the seat. (It won't fit in the same spot as the Y-connector)
