I like ground clearance but not lifts. If I buy a wolverine ill be looking at 4 nines around it as tall as possible.so what is the tallest tire?
Looked the blackwaters up they are 5 lbs lighter in a 28/9 over the 28/10 roctane. Thnx for the heads up. Leaning that way knowI am getting ready to buy the 2016 Wolverine R-Spec EPS. Looking for larger and better tires. Like the BLACKWATER EVOLUTION.
I'd have to look it up, I'm not sure. Probably not a significant difference.. But I'll look later.Epic, what's the weight difference between the XL mudlites and the XTR's?
XTR are a radial tire so there added weight in the belts. I was leaning towards the XTR's but went with the XL's. They rub on that one bolt head in the rear but only when you go over any large "yesmam" bumps we call em. Since I installed the 2" gorilla lift no rubbing at all.I'd have to look it up, I'm not sure. Probably not a significant difference.. But I'll look later.
I don't rub, but it's likely due to wheel offsetXTR are a radial tire so there added weight in the belts. I was leaning towards the XTR's but went with the XL's. They rub on that one bolt head in the rear but only when you go over any large "yesmam" bumps we call em. Since I installed the 2" gorilla lift no rubbing at all.
