1 - 12 of 12 Posts
Banned
Buy a 12v tachometer and run the tach wire which usually goes to the negative side of coil. I just tapped into the coil wire up front under hood at ECU. Tap into the solid orange wire on 2017 wolvy...check wiring diagram for your year.
2019 Yamaha Wolverine X2
Do you have a recommendation for the make/model?
Banned
Correction on coil wire color at ECU, it's an orange wire with small green stripes and it's on the bottom plug of ECU. You'll need to remove the 10mm bolt holding ECU in place to gain access to the wire..can't miss it. Disconnect battery prior to tapping into wire to avoid any possible electrical damage.
Banned
So has the waterproofed non-waterproof gauge held up?
My concern is the waterproof design. I keep them in the garage and am not a big mud fan but when i wash them off, they get very well washed. Plus why not get one that can handle it all. I'm looking at gauges built for boats right now but they tend to look booooooring....
1 - 12 of 12 Posts
