Tonight I added my 7th LED Switch in the Dash. I replaced the Seat Belt/Helmet LED with an In/Out Blue LED Winch Rocker Switch, 7 pin, DPDT, momentary, instead of using the Handlebar Switch that comes with most winches. The In/Out LED Winch Switch can be bought from China for less than $5.
The diagram below, in the black box, is the wiring schematic I used where the top and bottom LEDs (In & Out) in the Switch would both be on when the key is on. I labeled the 7 pins in the switch schematic (below) so others would not have to spend time using an Ohm/Volt meter to determine which pins in the switch to use for which wires.
