Has anyone installed a street legal kit on their Wolverine? If so, how complicated is it to do?
I know it's been awhile since the original post, but I finally got around to taking some pictures....
Here is the way I installed the kit supplied by the dealer for my buggy. The goal was to not drill holes for the plate, and not cut (splice) the existing wires.
Plate bracket bent 90 degrees, the two upper plate bolts are LED's
I used a male and female butt connector to put the license plate lights inline with the tail light wiring. I need to make one more for the yellow wire to have all my wires be the same length.
Mounted the horn there. This did require me to drill a hole for the bolt. There is a spot with the tit on the oil cooler guard as outlined in the service manual, but no bolt hole and this location was easier to get to.
Horn button location
and the connector location for the horn power
