Yes sir sometimes that is the case with disc brakes. Disc brake squeak does not always mean it needs anything except hopefully to work itself out and go away.
If it is just pad on disc squeak if you deglaze the disc with some sandpaper and also hit the pad itself on flat surface and sand it just a hair until you see it has new surface and shiny is gone when assembled it will be gone.
Rotating squeaks are not always from the brakes. Like you said could be axle too.
