1 - 9 of 9 Posts
· Registered
Do the rear rims on the rmax4 need to be changed to match the front for a square setup?
I believe you need matching rims and a spacer in the back on the 4 seaters. at least that is how it is on my X4
Reactions: wolvymanx4
· Registered
2021 RMAX 4 SE (XTR in US)
Hey thanks. I was hoping I wouldn't have to do that.
You can do a square set up on the stock rmax4 wheels but you loose a bit of diameter on the rear due to the width of the rear wheel. (I've done it) but it looks weird... I ended up finding two more stock front wheels for the rear. Also, I originally had spacers on the rear (1 inch) but they stuck out too far and threw mud everywhere. let me know if you need pics.
· Registered
Thanks for the info and please send those pics!
· Registered
So would I. When the factory tires wear out I’m planning to square it up with 31’s or 32’s depending on the gains from whatever springs I decide on.
1 - 9 of 9 Posts
