1 - 20 of 40 Posts
Some new stuff for my Wolverine.
12" LED front light
2x4" LED back up lights (you can see how bright they are with my garage lights turned off, and LED's lighting up what they're pointing at...WOW)
4000 lbs Warn
Switches on the dash from left to right...winch, front LED, rear LED's remote switch for winch
And my new T4 tracks from Camoplast (will take pics later)
I didn't have the washer fluid/reservoir kit installed. My feeling was that I only plan on using the window during the winter..so no dust, just snow. I didn't want to risk using the wiper and washer fluid in the "dusty months" for fear of scratching the window up. Instead, if needed, I'll just carry some water mixed with Windex, and a good squeegee. My other plan is to use the Yamaha folding window from spring to fall.
Might all be overkill, but ........:rolleyes:
Took some picks of my tracks. These things are a sweet piece of kit. Looking forward to rolling thru the snow this winter. I hear great things as to what tracks will allow a wheeler or sxs to do in snow....hope so
Very nice! I should have a very similar setup, going with the T4S also. What I need to decide on is what I want for LED light bar. Definitely a combo pattern but not sure on the width yet.
Well after riding yesterday I did realize that my 12" LED bar vibrates quite a bit where it sits on that "indent" on the roof....mostly at idle...not as bad when on the gas. I like the light but need some ideas on stiffer support at that location.
My buddy has a 32 or 36" light bar and has very little viration as it mounts at wider points on the roof.
I may look at swapping my front light bar for my two rear lights.....
Another realization (while lying in bed at 4:30 this morning lol), was that Im now not sure if Ill have enough clearance for my plow blade and my tracks. These tracks add another 26" to front of bike. Even if theres enuf room...not sure if there will be enuf to angle blade. And since plow is still on back order...can't tell....
November WOTM Winner!
Here's what I did for a brace behind that indent and have no problems with vibration. Just made a bracket and used a couple u bolts. Might not be the prettiest but works well
you will probably have to extend your plow mount with the tracks on,it will be nice to get pictures of how your track springs hook up on your machine when you get them mounted.
Discussion Starter · #11 ·
Got the front tracks mounted. Took a lot longer than expected, especially after snapping one of the tension spring bolts in half...lol. Set the angle of attack, alignment and deflection. That took most of the time...and was told it does the first time. Should be good to go now.
July WOTM Winner!
Can you get out of the garage? Looks pretty tall. I like it.
July WOTM Winner!
I'm also wondering what the overall length and width is. I'm looking to buy a trailer soon and would like tracks someday. Would it fit on a 77"W x 144"L ?
Discussion Starter · #18 ·
Bike with no tracks is 120" (10')...with tracks is 180" (15' 5")
Tracks add 36" to rear, 26" to front and 8" to width (4 per side)....so just over 5' of extra length and 68" (5' 8") of width
My trailer is a deck over and measures 78" wide x 150" long. (Triton deck over aluminum)
sooo....bike will fit width wise with a little room to spare, and have an extra 30" over the rear. But I have a salt skirt on front of trailer and can easily take off if transporting bike. So tracks will hang over each end by roughly 15"
That should work.
Hope that helps
1 - 20 of 40 Posts
