1 - 3 of 3 Posts
I bought a flexible 18" antenna from Walmart and a whip mount off of Amazon then hooked up sirus thru the adapter. Listen to what I want anywhere
Does it work when the engine is running. Also is your the LE build.
You need a signature with the full machine build spec's all guess work and questions. Apparently these onboard electronics are emitting EMI interfering blocking the FM signals.
Yes it works with the engine running. I had an older sirus head unit laying around that plugged into the accessory jack in my old work truck.
I just upgraded the antenna on the ssv unit to the flexible one from chinamart to help the ssv unit.
If you order a new unit from Amazon I think they're like 50 bucks with the auto kit and 3 free months.
1 - 3 of 3 Posts
