When is the slug kit needed? Is it only needed on huge mud tires if so what size?
I will be running the stock 26 inch tires or maybe 27 inch Big Horns.
I will install the belt drive kit for a lower gear for rock crawling in a month or so at about 2,500 miles.
The Viking and Wolverine have the same belt drive including the rollers. The Wolverine has a different belt.
What is the stock roller weight and does the belt drive kit use a lighter weight for more revs.
What is the shift out rpm stock? What is the shift out rpm with the kit.
Except for very slow driving the rpm is from 4,000 to 6,500 rpm. The rev limit is 7,000. It back shifts good with hard throttle. Top speed in deep loose sand is about 46 mph. The belt temperature runs from 140 to the 160's most of the time. On 1,000 foot elevation gain hill climbs it goes in the 170's and after 10 miles of deep loose sand wash runs I got 185 degrees. My stock 08 Teryx went just over 200 on the same run and I got about 5,000 miles out of the belt. My buddy has it now with over 16,000 miles on it. FYI the belt glue melts at about 260 degrees. Anything under 190 is fairly good.
