1st it shows you they arent even torque down, 2nd it was overfilled.So I just checked my machine and the hose clamps just towards the rear of this drain look like they are leaking oil, how concerned should I be?
They could be loose. Slightly loose isn't catastrophic, but severely loose means you could be ingesting dirty air. Leaking oil means your system is\was overfilled and you need to drain by pulling the inspection drain cover off.So I just checked my machine and the hose clamps just towards the rear of this drain look like they are leaking oil, how concerned should I be?
Well thankfully the dealer just warned me that this may be a potential issue and I should look at putting a proper hose clamp on mine. :neglected:This just happened to mine last weekend because the clear drain plug was missing. :zx11pissed:
Had to pull the plugs to get the water out, but fired right up afterwards.
That's the upgraded clamp. I think it's sufficient but if you want to replace it with a hose\worm clamp you can.I didn't the air filter system check and it passed. This is the clamp that came on my 2020 R-Spec, should I still add a hose clamp for assurance.
me too! :frown:What I wish I'd done when my machine was new:
Looking at mine now I'm lucky if I can even see them under the mud baked onto them. I'll be lucky if I can get one out without breaking.What I wish I'd done when my machine was new: Take out the (6) bolts holding your exhaust tip on. Then put anti-seize on them, and reinstall them. You can do one at a time. Then later (hopefully!) when you have to service the spark arrestor the bolts will come back out.
Sounds like it’ll be time to get out the blue wrench out for a little assistance. Or B try some ATF/Acetone mixed together it’s amazing what that combo will break loose.Looking at mine now I'm lucky if I can even see them under the mud baked onto them. I'll be lucky if I can get one out without breaking.What I wish I'd done when my machine was new: Take out the (6) bolts holding your exhaust tip on. Then put anti-seize on them, and reinstall them. You can do one at a time. Then later (hopefully!) when you have to service the spark arrestor the bolts will come back out.
I did manage to get all mine out. They were all easy enough to break loose but it seemed like the last 2/3 of the bolt threads were the most corroded.Looking at mine now I'm lucky if I can even see them under the mud baked onto them. I'll be lucky if I can get one out without breaking.
So I was doing my 160 hour service today and found mine was missing completely!!Thanks InfidelMT for doing this video, showing the test:
I've heard of only a handful of new Yamaha SxS that didn't have the engine air intake ducting properly installed or the clear drain check hose installed. The results were that one engine ingested water and hydro-locked and the other had to be rebuilt due to dirty air.
While these instances are rare, you can do a very simple test to see if your engine air tract is sealed properly. Pop the hood off so you have access to your air filter cover and start your engine up. Next place your hand over your air intake or cover it with something flat (don't worry, you have 2 air filters to prevent them from getting ingested into your engine) and your engine should die pretty quickly. If it keeps running and you hear suction from somewhere then it's time to start a visual inspection of the entire air tract system. This is a simple 5 minute test and could save you the hassle of trying to fight a warranty claim later down the road where you didn't notice the problem in time and the dealer tries to deny it.
Here is a picture of the clear drain check hose located underneath and forward center:
Replace that flimsy tension clamp with a proper hose/worm clamp.
Location of drain via parts diagram. You'll looking at #29, 30 and 31
A member of my FB group has a 2020 X2 XTR and it looks like Yamaha is now putting a beefier clamp on the air intake check/drain. This should be a TSB and all prior vehicles updated, easily done by the owner.
Amen to that! If not for this community, I never would have checked!It’s a good thing you checked Harry.
I love this forum for discovering information like this.
RNF where is this located ? front ? rear ? middle ?I did the air filter system check and it passed. This is the clamp that came on my 2020 R-Spec, should I still add a hose clamp for assurance.
