They had a bin of them at work all different sizes. Not sure who it's made by. Yeah I wanted to be double protected. lol. Just find any type plug and jam it in. Probably would have been fine with a hose clamp but wanted to make sure. I do my own oil changes and it's 3.5qts max with oil filter. Never had a problem or any oil in my intake.Where did you pick up the plug? Any specifics would be great. I put a hose clamp on mine but double coverage sounds like a good idea if you are careful measuring your oil during changes and don’t overfill.
My 2020 had the flimsy clamp as well; replaced it with a hose clamp.I just checked my 2020 after reading this post and mine still has the flimsy wire clamp on it, I'll be putting a better clamp on today.!
Anyone know what size this new style clamps is? Im not a big fan of the hose clamps because sometimes I've seen them not maintain their round shape. For now I've just turned The factory flimsy clamp so the ears are on teh top side until i fint the clamp i want.1st post updated with new style clamp that Yamaha is using on the air intake visual inspection tube/drain
From the treads I’ve dug up on this seems like a common issue and would assume maybe my dealership over filled oil..glad i know about this thanks to all the great help here at the forums!
The check oil level routine is multistepped, complicated by the dry sump set up. You have to start the engine, let it warm up, then shut it down, unscrew the dipstick, clean it off then put it back into the hole - but do not screw it in, just put it in till it stops then pull it out and check the level.From the treads I’ve dug up on this seems like a common issue and would assume maybe my dealership over filled oil..glad i know about this thanks to all the great help here at the forums!
Good explanation. I’ll add (Re-iterate) that it checks different when cold vs. hot. Follow the procedure. When you change the oil it’s much easier to become comfortable because you KNOW how much you put in. Today I did my third oil change and after 3.5 quarts it was just a hair above the full mark. I checked it multiple times over multiple heat cycles in one day. So I cracked open the oil tank drain and let a little out. Repeat until I got to 85% on the dipstick. You do not want to be over on these designs or it will just collect in the air intake drain.The check oil level routine is multistepped, complicated by the dry sump set up. You have to start the engine, let it warm up, then shut it down, unscrew the dipstick, clean it off then put it back into the hole - but do not screw it in, just put it in till it stops then pull it out and check the level.
Engines come from the factory with oil in them, dealer is supposed to check the level in the pre delivery check. I assume if they didn't let it warm up enough, they would get a false low oil level reading, so they "top it up" meaning it is now overfilled.
I don't know if this happened to you, just presenting a scenario that could lead to overfilling oil.
