Some of been around a while known/read about the COOP MODS for low end improvements and a different ramp on the sheave once machined. However, it all started with a dirt cheap SHIM solution to shim out up to 2.0mm if there was sufficient engagement left and clearance.
Kingquad owner were doing it and I did a 1.5mm shim on the two I had.
I feel this CVT should be able to handle a 1.5mm shim set without issue but haven't heard mention of it anywhere. I'll ask my dealer if they are carrying the shims or not as they'll have it apart and hopefully pop them in.
