Took the sway bar off and better suspension and not too bad on high speed corners. Will wait until I get the belt kit and Yamaha aluminum skid plates for serious rock crawling. Also a-arm guards. I will need a really low gear for the Stupid Hard low speed stuff so I won't smoke the wet clutch. The super low gear on my Pioneer 500 has spoiled me a bit. Right now I ride the easy stuff and keep the speed at 6 mph and above. If I can't get a low enough gear with the belt drive kit I will run smaller tires and add more spring preload for the necessary ground clearance.
