rock crawing
1890 Views 7 Replies 5 Participants Last post by  Hunterworks
how are these setup for slow technical rock crawling
i don't own one at this time but I'm looking to purchase as soon as my rzr sells
thanks
1 - 8 of 8 Posts
thanks
been up a coulple moutains in loose rock ,but nothing technical and worked well,some of the videos show them doing good ,the low end seems to have lots of torque
I have done a little. Clearance is the first hurdle you going to have to overcome. The wolverine has almost 2" less clearance than the rzr, mav. I put a few dents and dings in the skid plate playing in the rocks. But there is plenty of power, and traction. Thanks to what I feel is the best 4wd system in the sxs market. If your good at picking lines and stick to the top of the rocks in the gardens it does well. But would grit my teeth often as I drag my plate across them.
sounds like uhmw skids and lift will be needed
Slug kit will keep the clutch engaged too. Here's a vid after I did the Hunterworks sleave/clutch kit install. Before I would give it gas..it would rev a little and then move. Made it kind of jerky getting it loaded on a trailer or rock crawling. Now.. no problems at all. Smooth.
Reactions: 2
how hard is the slug kit to install
Not very hard. I did Primary sheave, Secondary sheave gold spring, clutch slug kit all at the same time. Just watched the hunterworks video's a few times :D One thing I didn't have was the spring tool for the secondary spring. It's a 45mm nut and didn't have a socket that would fit it also. Watched a vid of just standing on a tire to remove and replace it. So I used the left rear tire from the wolverine. Put the rim over it and stood on it.
For the Slug kit, not hard but may as well do the sheave while at it. Have to take the sheaves off to get to it. Hardest part was just removing all the old gasket material for the new clutch gasket. The front facing wire brush on the drill makes it ok but still a pain with the mess.
So for hardest parts, secondary spring, gasket removal, then putting the dang bed back on. Nothing that bad really.
Reactions: 2
Here is a link to the Wolverine page on our site
Each product, example sheave and slug kit has a link on it for a install video
link to parts for - Yamaha Wolverine
Thanks,
Todd
Reactions: 1
1 - 8 of 8 Posts
