Quick question has anyone encountered the dump box alignment off causing the box to rub on the factory glass rear window kit ? I have checked quite thoroughly underneath and it appears to me that where it is hinged it is welded to the frame and pins are uses as part of the hinge system, this alignment problem is also causing me not to be able to install the plastic door shroud that is supplied with the back window kit for the solid doors.
Any advice would be appreciated.
Thanks Paul
Thanks Paul
