RMAX 1000 PRIMAL SOFT CAB ENCLOSURE UPPER DOORS
Link: Yamaha Wolverine RMAX 1000 Primal Soft Cab Enclosure Upper Doors | SuperATV
These Upper Doors Are Super Tough
There’s nothing worse than missing quality trail time because the weather turned bad. A little rain never hurt anybody, but if it’s really coming down, you’ll need some extra protection to ride comfortably. That’s where SuperATV’s Primal Soft Cab Enclosure Upper Doors come in. Add these doors to your Yamaha Wolverine RMAX 1000 to shield you and your buddies from rain, mud, and cold weather. They’re designed using our premium Pel-Tek technology to be water resistant, versatile, and extra strong. You can even pair them with our windshields to boost your cab protection.
Made with Pel-Tek Technology
You won’t find premium soft cab enclosure components this tough anywhere else. Our PVC-backed polyester doors utilize Pel-Tek technology to prevent punctures, abrasions, and mildew. This material is finished with a premium stitching technique and CNC cut for a tight fit that won’t stretch over time. And installation is easy! Our doors secure to your cage using heavy-duty Velcro, snaps, and cinch straps—they’ll stay on through virtually anything.
Windows Offer Exceptional Clarity
Nobody wants to sacrifice visibility for protection—and with our soft doors, you don’t have to. The soft vinyl windows are UV resistant so yellowing and cracking will never be a problem. We also double polish them for exceptional clarity. No matter what you pit them up against, your windows will stay as clear as the day you got them.
Versatility to the Max
When you need protection from the elements, these soft cab enclosure doors stay closed tight thanks to snag-free zippers. And when you’re ready to feel a breeze or just want to keep the mud off your doors, you can roll them up or zip them off to completely remove them. Heavy-duty snaps will keep them out of the way. These Yamaha soft doors are the epitome of versatility.
Make It a Full Cab Enclosure
Why not complete the package and go for a total cab enclosure? Our soft upper doors are compatible with our windshields and your stock lower doors, so you can ride in comfort through all seasons and trail conditions.
- PVC-backed polyester utilizes Pel-Tek technology for maximum strength
- Uses double-polished vinyl windows
- Resistant to water, punctures, abrasions, UV radiation, and mildew
- Heavy-duty snaps hold the windows open for more airflow
- Industrial-strength Velcro strips and snaps hold the doors securely to your frame
- Includes all hardware and instructions
