81 - 94 of 94 Posts
2021 rmax4 se (xtr),super atv flip,soft enclosure,storage box,ssv works,
Just to be clear are you attaching the case right to the Yamaha cover plate on the pull down cover. I have a tab a 8 coming with a otter box defender case. From the pictures it looks awesome
2021 RMAX4 1000
Discussion Starter · #82 ·
Yes. Check out post #3 in this thread. You can see where I drilled my holes in the Yamaha filler plate. Actually a nice bonus because that Yamaha plate is only $5 to replace if you ever need to put it back to stock to sell it or something.
yes, drill holes through the case. then I used 4 0.25" spacers and machine screws with nylock nuts to bolt to the Yamaha block-off plate. I have a 90 degree USB-C cable coming that will get wired up into switched 12v power.
I really like your guys layout with the tablet mounted to the plate.
I went a different route though. I replaced the plastic plate with an aluminum one and mounted 2 balls on the plate.
Can hold my phone and tablet. I have several different length RAM arms for motorcycle and kayak us. So lots of options of positioning the devices for the driver or passenger.
I covered the aluminum plate with some carbon fiber wrap and a little batman reflective decal to finish things off. Lol.
And my OCD had a real battle between lining up the seams on the ball or lining the screw holes up. The balls won out.
Hood Vehicle Automotive lighting Grille Motor vehicle
2021 Canned Ham Maverick Sport Max 1000r
got our tablet holder and tablet case in finally. I ended up having to remove the velcro hand strap on the backside of the case for it clamp down.
96695
96697
96699
96701
this last one shows the dual usd port stashed on the inside to keep the battery charged while riding
2021 RMAX 2 XT-R
Man you guys have done a great job with these tablets. Hats off to you!
2021 RMAX4 1000
Discussion Starter · #87 ·
Hahaha. I totally would have went nuts making that decision too. 🤪
Reactions: Maggot
2021 X4 2021 Kodiak 700
Are you guys ordering the wifi only Tab A or the cellular and wifi?
Mine is wifi only. I use onX on the trail and it works great.
2021 RMAX4 1000
Discussion Starter · #90 ·
Mine is the cell model even though I only use it on wifi. I got a good deal on the Sprint one. Even though we don't even have sprint out by me. lol. It is fully functional on wifi though. Just pops a notification symbol in the status bar telling me it's not active every so often.
Sweet I got my Tab A 8" and downloaded OnX Elite on it and am just waiting on the otterbox
I have done the same setup as you (A7 lite otterbox defender) but I'll be damned if I can find a right angle cable that's small enough for the space and big enough for the Otterbox case. Any chance you could share the one you found that works?
2021 RMAX4 1000
Discussion Starter · #94 ·
I bought this one from Amazon and it fits perfect. Look at post #70 in this thread. I have some good pics of them.
81 - 94 of 94 Posts
