1 - 5 of 5 Posts
I was out riding today and notice my rear differential overflow tube, (tube on top of the differential) was dangling down pass the skid plate by the right rear tire. Does anyone know where this tube is suppose to be located so it doesn't dangle
Very very common. Everyone should look to make sure it's up by the throttle body. Mine was sitting on the skid plate under the gas tank. There's some lose plastic holders that you route it through up toward the throttle body. I made sure to zip tie mine up there.
Here's the tube going up the inner frame rail. I glued a 90* bend on the top so I knew which tube was the rear vent and also to help hold it up there with the zip tie.
1 - 5 of 5 Posts
