121 - 126 of 126 Posts
Demon Axles will be available in Nov
Reactions: SKELLEY521
Discussion Starter #124
About the same as I have been getting. These rear inner CV’s can’t handle the little bit of increase in angle from The Eibach springs or any lift. Any one that does anything to increase the angle just a little should be ready to get new rear axles later on.
They lasted 2000 Km , 1800 of witch was only Eibach springs. The PerFex lift just finished them off even with limiting straps.
And before someone chimes in and says " You got a lift so expect problems " Riddle me this ? Why are the front CVs taken it so well ? and stay at 40 deg all day long ?
Pretty sure this is just an horrible design mistake. No way should the cage rub inside with just 1.5" of lift.
I just installed an allballs 8 axle on the passenger rear. The outer boot on mine blew out on a high speed ride a few weeks back. To bad the Demons weren't out yet.
