I was finally going to get to ride my side-by-side today when it was warm it up I noticed I had a radiator hose leak. It is the one that I plumbed in from the heater exit back to the radiator I believe. It hooks into the y up front. I have it covered with 1” heater hose to protect it. The hose is leaking inside the larger hose somehow and spitting fluid out in between the 2 hoses. I am planning on changing out the 5/8 line and either covering it with braid or getting a heavy duty hose maybe even a puncture resistant hose if they make them. I really don’t understand how this can be leaking inside the 2 hoses. Maybe the outer hose rubbed a hole on the inner hose. I can figure it out. Any way can someone recommend a good hose or braid for this. It needs to be protected from sticks that get under the cab. If anyone can help thanks.
