So,
I'm about to pull the trigger on the PC5, but have a question. The input side of the PC5 is the TPS, Crank Position Sensor, Spark timing (which it's modifying, in reference to the CPS), and Pulse Width on the Injector (which it's modifying on the firing of the Injector) nothing on the PC5 to determine altitude from the ECU.
On the Wolvy there is a Intake Air Pressure Sensor input on the ECU, as well as Intake Air Temp (No Barometric Sensor which is necessary for determining Altitude). According to the Service Manual it determines the Altitude, but I believe this is ONLY at startup before the engine cranks, then the ECU uses this for the Intake Pressure, which is NO longer Altitude Pressure. And when riding, in 20 minutes I can go from 5000' to 8500'.
Those of us who ride between 4500-8000 ft (I live at 5000 and ride mostly above this altitude), O2 is not nearly what it is at sea level. The PC5 becomes completely useless and real quick under all circumstances, which is kinda hard to swallow for $319.00. Since the PC5 doesn't know the altitude or the Injector pulse width due to altitude, it's making a real huge assumption on the modified pulse width it's sending to the spark and injector!
Sea Level - 100% O2
1000m (3281') - 88% O2
2500m (8500') - 73% O2
WHAT I'M TRYING TO GET TO WITH ALL THIS...
If the Air Pressure Sensor on the Wolvy is not calculating a true Altitude all the time then the EFI will be off once you get moving, and no PC5 map will fix this. The only way to have an optimum, or even close to optimum ratio is to use a Lambda sensor (Wide Band O2 Sensor). And that means throwing another ton of money at this whole problem, which is why I'm a firm believer in Lambda sensors from the factory.
And, if I'm thinking this through correctly (I may not be... but it makes a ton of sense to me), even if the wolverine ECU is making the necessary changes to the injector's pulse width, the PC5 doesn't know why it's doing it, and is just making some wild guesses. So, if I tuned it to about 13.5 on the ground, I don't see how it stays there once up in the mountains.
Will I buy the PC5, yes only because the current AF ratio from stock absolutely is way too lean and it's the only way to fix it (no one does ECU flashes), that doesn't mean I'm going to be happy about it. Any help on either correcting me or getting to answering this will be great.
Thanks-
Sea Level - 100% O2
Thanks-
