Will fit:
Yamaha Wolverine : 2015+
The SuperATV Plow Pro snow plow is available in three lengths and constructed of industry leading, heavy duty 10 gauge steel with a 7 gauge steel cutting edge. It's winch operated and adjustable from side to side with five different angles from 0 to 23 degrees. Have a lift kit on your machine? Plow Pro’s frame is adjustable to compensate for any size lift kit allowing a level blade at your machine's ride height. Each blade is equipped with plow markers so you’ll always know where the sides of the blade are while operating.
Mounting of the snow plow is a bolt-on design, no drilling necessary. The mount can remain on the machine with a blade quick connect for easy attachment. The plow’s blade shoes are free spinning for a longer life. This blade is tough! Not only is it heavy duty 10 gauge steel, the blade has an 8mph impact rating designed to auto rotate if you encounter tree stumps, large rocks or other solid debris while plowing. This rugged construction will give you years of snow removal!
Heavy duty 10 gauge steel construction
Available in three lengths: 52”, 60” & 72”
Winch mount: bolt-on design with quick connect
5 adjustable plowing angles from 0 to 23 degrees
Easy to install and operate
Interchangeable blades and mounts
YAMAHA WOLVERINE PLOW PRO HEAVY DUTY SNOW PLOW - SUPERATV
