1 - 3 of 3 Posts
I'm looking to create a better ride experience, especially for my rear passengers (stock rears must go). I'm looking at the Bandit 46 gen 3 series (when they're available again) and adding the perfex lift (1.5" option in rear). Any reason this wont' work? I've heard the Bandits add about 1.5" total and wanted to get the same height I got (maybe slightly more) than I got out of the SATV 2" spacers I have on there now. Thoughts?
I have the bandits on my x4 and got about 1- 1.5" lift with just the shocks. I also run 28" carnivores giving me about 14" of GC in the rear. For me this is plenty and I think Im on the edge of the safe limit for the CV shaft angle. I could crank my shocks and get even more clearance I believe. I currently have the rears set at zero preload and have the fronts cranked up a bit to give me a level ride. Im not a big fan of the lift kits as you are altering the suspension geometry and potentially placing more strain on the mounting points. Just my .02 cents.
I did 1.5" over 2' . You will need Demon HD axles
1 - 3 of 3 Posts
