I will watch mine.. Thanks for the heads up
From the front, I don't think you can pack the back. I believe it is all covered with the cowl for the fan. It was so bad on the bottom on both sides, where pic is that I couldn't see the fins. I guess the only thing to try is making some deflectorsWas the mud packed from the front or the back?
My Maverick did this ALL the time. Unfortunately, I don't think any machine is immune to this. Mud in the radiator is just that. Unfortunately, putting stuff over it will probably reduce air flow. If you prevent mud from getting to it, you also prevent air.Yeah i can't believe no one else is having this issue. I can't imagine I'm the only one riding thru mud like this. To be honest I was only riding around 30 mph when it started overheating, so its not like I was on it hard
I was thinking restricted air flow would be better than a packed radiator. What I was actually thinking was some shields with some holes or slots in them to keep out most of the mud and still allow a little air.Well mine was packed up pretty good but it was also pretty cool where I was at, only 60s-70s during the day. Just a tip, you could always pack a few extra water bottles when you ride(we carry a cooler anyway)and if it gets too clogged, poke a hole in the cap of the water bottle and squeeze it on the radiator. It certainly won't be like having a hose, but it will definitely help. As for the guarding idea, I wouldn't be too concerned with it blocking the airflow, as you are not relying on vehicle speed here to get airflow. The fan shroud is designed to flow an adequate amount of air while the vehicle is parked, so as long as the guarding is not right up against the radiator, you should be just fine.
I'm sorry but I didn't exactly buy the machine to ride around slow or avoid the mud holes with, nor did they design it for that purposeThis is not the wolverine's fault, its the mud in your radiator's fault. Keep it clean, like someone said bring something along that would help you wash it out if your riding in mud that often. I just rode threw slow trails this weekend in low for over and hour in almost 90 degree humid temps and the machine never once got hot.
You think they designed it to overheat and plow threw deep mud then? What I was explaining is that if you can ride it slow in low for hours in very hot temperatures without it overheating, its not the machines fault that its overheating on you, its simply the fact that the radiator is plugged and I advised you to find a way to clean it out if thats the type of riding that you do. I was just telling you why your more than likely having an issue. My friend carries a sprayer in his bed just to avoid this problem if it occurs.I'm sorry but I didn't exactly buy the machine to ride around slow or avoid the mud holes with, nor did they design it for that purpose
I'm sorry and dont mean to offend you in any way but I don't see carrying a sprayer around as a permanent solution to keep a machine from overheating that was designed for off road use.You think they designed it to overheat and plow threw deep mud then? What I was explaining is that if you can ride it slow in low for hours in very hot temperatures without it overheating, its not the machines fault that its overheating on you, its simply the fact that the radiator is plugged and I advised you to find a way to clean it out if thats the type of riding that you do. I was just telling you why your more than likely having an issue. My friend carries a sprayer in his bed just to avoid this problem if it occurs.
