1 - 4 of 4 Posts
Let's get this straight... My head is spinning on this going from 2wd to 4wd and back. I have the '21 RMAX4. Is it OK to go from 2wd to 4wd while moving? on the fly? Or should we come to a complete stop then turn dial from 2wd to 4wd? This has been discussed so many times and still confused.
Wheel Tire Plant Sky Vehicle
2021 RMAX4 1000 LE
Yes YOU CAN shift 4x4 on the fly. Just let off the throttle , and coast while flipping the switch.
Avoid doing it at high speeds, while under throttle , or under load ( like spinning in mud).
I do it at lower speeds all the time.
DO NOT TRY SHIFTING DIFF LOCK WHILE MOVING.
1 - 4 of 4 Posts
